Trailer brake lights won't work on 2500HD
Old Jul 18, 2014 | 7:44 AM
Roll Tide's Avatar
Default Trailer brake lights won't work on 2500HD
I have a 2002 2500 HD 6.0. Has factory tow package and wiring with 7 pin connector. When I hook up my utility trailer the turn signals and running lights work but no brake lights. All lights work on the truck and I've found no blown fuses in the dash or under hood fuse box. The only thing that doesn't work on the truck right now is the emergency flashers. Anybody have a solution? I can't be the only one with this problem. Thanks in advance for any help and suggestions.
Thanks,
Steve
Old Jul 25, 2014 | 5:29 PM
Roll Tide's Avatar
After 143 views and not one answer I found the problem and everything is working now. Uuuuh....Thanks?
Old Jul 25, 2014 | 8:32 PM
old dog's Avatar
hello,i would check the ground's on the trailer lights and then see if you are getting voltage at the brake light pin on the truck plug when you hit the brake Pedal .
Old Jul 25, 2014 | 9:26 PM
don't post the fix...keep it a secret....shhhhhh.
Old Jul 26, 2014 | 6:41 AM
Roll Tide's Avatar
I am.
Old Jul 26, 2014 | 8:32 AM
143 people did also
Old Dec 17, 2014 | 2:41 PM
n1njazx7's Avatar
I just ran across this thread and mine had the same problem. The trailer place I get my fifth wheel from fixed it by installing a converter box. I would like to know what was really wrong with the truck. As you must be smarter than the rest of us I'm asking nicely, please share as no one else must know either.
Old May 25, 2020 | 9:55 PM
Noel Barrick's Avatar
Default Solution!
I was having issues with my trailer brake lights not working, but turn signals and all other lights working. I scoured the internet to find a solution and stumbled on a thread with solution. They were having the same issue, and the problem ended up being the turn signal flasher, between the steering column and the fuse panel in the cab. Hope this solution helps save some time for people having this issue.
Old Sep 14, 2024 | 5:08 AM
WV Trails's Avatar
Default Solution confirmed
Thank you Noel. Roll Tide - what’s wrong with you?
I spent hours checking all my grounds and my trailer brake lights still didn’t work. A few months prior I switched to all LEDs in my truck and bought a cheaper LM487 turn signal Flasher relay off Amazon. After reading Amazon reviews and saw customers were have the same trailer brake light issues, I went to NAPA and bought the LM487 for 3 times the price and my lights are working fine. Who knew the trailer brake lights had anything to do with a signal flasher relay? I didn’t.
SeanJoelson
Sep 14, 2014 9:42 PM
Hectorson3
Sep 13, 2014 12:22 PM
hoghntr1987
Mar 7, 2014 11:22 AM
LeeA
Apr 13, 2012 4:28 AM
tahoeowner98
Aug 18, 2011 1:32 AM
