transfer case slipping/grinding
My '99 silverado 1500 4wd started making this grinding noise when I take off. Mostly just when under load or if I hit the gas too hard. Transmission is working good. I had it rebuilt a couple of years ago. The only thing I can think of it is the transfer case. I have talked to a couple of people and searched some forums. Maybe a slipping chain in the transfer case or I saw a post about some snap ring in the tail shaft breaking. Do you guys have any experience or thoughts about my truck?
re: suzuki samurai transfer case
I say screw it, it s costs the same to rebuild one or buy a functional used one.
tcase is seperate and will need to be changed seperately. service manual calls for automatic transmission fluid to be used (nissan's matic D fluid), but lots of us use the same gear oil used for the manual transmission for the tcase. just in case the oil seal between the transmission and tcase leaks. then the fluids that mix are the same.
i went to a tranny shop about my blown tranny and the guy at the shop told me that anyone can rebuild a tranny of transfer but you gotta have the ***** to try, he said they arent difficult but you have to go for it, im actually going to try to rebuild my tranny this weekend
salvage yard transfer cases
I have had a lot of good luck with these guys, transfer cases, they have a bunch of salvage yards across the country
Had the front driveshaft replaced 5k ago because of the 2 inch lift, all greasable ujoints. Will buy the new seals tomorrow. Also, the "high/low" lever on the new transfer case is very difficult to move back and forth. Is that normal and will it free up once I connect my existing cable or could it be an indication it may lockup in the future?
