Transmission flush does it void extended warranty ?
Old Jan 6, 2021 | 8:50 PM
jillbinkert's Avatar
Default Transmission flush does it void extended warranty ?
Hello
45,000 service dealership wants 475.00 + tax
for transmission flush and something with fuel system service
Does flushing your own transmission fluid and filter replacement void your extended warranty
2017 chevy Silverado 1500
my brother offer to do it for me.
Thanks
Jill
Old Jan 7, 2021 | 7:34 AM
oilcanhenry's Avatar
Originally Posted by jillbinkert
Hello
Thanks
Jill
Probably does, but auto transmission flushes have a bad reputation for causing problems. Just have the transmission fluid dumped and use Dexron VI full-synthetic auto trans fluid and a filter change.
Old Jan 10, 2021 | 10:54 AM
Gumby22's Avatar
Not all DIY services void warranties. In the case of transmission service, make sure to use GM specific transmission fluid - I can’t remember what the most recent version of Dexron is, but it should be in the owners manual under “Capacities and specifications.”
Read the terms of the warranty - it will specify exactly what you can and can’t DIY.
Old Jan 10, 2021 | 11:12 AM
I just verified with my service manager he said as long as I keep receipts proving I did it properly my warranty is not voided
Old Jan 10, 2021 | 5:33 PM
Gumby22's Avatar
Then you should ask for clarification on what “proves” you did it properly. For example, a receipt for ATF doesn’t prove the flush was done correctly - it only proves you purchased the ATF.
I’m not saying GM will make that specific argument, but what your service rep tells you and what the management team above the service rep decides can often be 2 different things. The service rep wants to help you receive the best service possible - meanwhile the manager(s) above the rep are trying to save money anywhere they can and have no problem putting your service rep in a position to take the blame.
Old Jan 10, 2021 | 9:51 PM
Rednucleus's Avatar
Is the trans flush a listed needed maintenance item fro your vehicle, or just a recommendation? If yes, maybe have an independent licensed mechanic do it at a more reasonable price, and better protect your warranty. If not required maintenance, why is it being recommended?
Old Jan 10, 2021 | 11:16 PM
maybe a tranny that's on its last leg, but not with 45k
Old Jan 11, 2021 | 3:45 AM
Yeah, 45K is nothing. Dump the fluid and the filter, refill and keep on truckin'.
2016suburban
Mar 13, 2022 2:18 PM
Linda Atkinson
Jan 8, 2019 9:05 AM
Sohlden.renae@gmail.com
Cruze
Oct 2, 2017 7:39 PM
Jonzun1
Feb 15, 2016 3:33 PM
miss24fan
Sonic (Aveo)
Jun 10, 2013 12:46 AM
