Truck makes clunking noise
Old May 9, 2010 | 5:55 AM
Jakester's Avatar
Default Truck makes clunking noise
04 Silverado makes a clunking noise at first acceleration - almost feels like drivetrain starts out first then the rest of truck decides to follow after it! Heard of this?
Old May 9, 2010 | 9:09 AM
brewe's Avatar
15 Year Member
I had same noise when starting from dead stop. I greased splines on yoke of driveshaft where it slides into transmison and trouble was fixed.
Old May 9, 2010 | 10:09 AM
Jakester's Avatar
thanks - will give it a shot
Old May 10, 2010 | 6:33 AM
wes29's Avatar
I had an '07 that did the same thing. It is a yoke issue. Greasing will temperarily solve the Prob. I had to grease the yoke every few months. Took it to the dealer and all they do is the same thing. Should be a recall some where down the line.
Old May 12, 2010 | 9:13 AM
juddkennedy's Avatar
could also be the intermediate steer shaft. If youbuy real good silcone based grease it will keep it from rattling for a few months. The factory shafts are not the best. $60-$70 from local auto store.
Old May 12, 2010 | 10:17 AM
ristpin's Avatar
I have a similar issue with my '04 Silverado. Did you guy's use any special type of grease? Silicone, etc.?? Thanks.
Old May 13, 2010 | 4:14 PM
Jakester's Avatar
Actually the intermdiate shaft issue has been going on as well. I plan on greasing it too but looks like it will become routine maintenance as well.
Old May 13, 2010 | 4:16 PM
Jakester's Avatar
I would use exactly what JuddKennedy said - a silicone base grease - but might I suggest something High Temp as well. Being near the motor it tends to dry it right off the shaft rather quickly.
mojo
Mar 10, 2013 6:42 AM
allyourbase
Jul 12, 2009 6:43 PM
peterpiepr
Sep 12, 2008 10:04 PM
Courtzilla
Mar 19, 2008 6:08 PM
dzonen
Feb 15, 2007 11:13 AM
