Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
how to reprogram tcm on2014 sonic
Old Mar 17, 2018 | 12:08 PM
asaguahu's Avatar
Newly Registered
Default how to reprogram tcm on2014 sonic
I would like to know if tcm on a 2014 sonic lt 1.8 can be reprogramed and how
Old Mar 17, 2018 | 6:53 PM
now sure of your intentions:
not sure of the build for this vehicle; automatic transmissions can have their own module... tcm or be control by the powertrain module.. pcm
-if you have a transmission complaint you can check with the dealer to see if a tcm update is available. they would have to connect to the car with a dealer scan tool.
-tuners can adjust tcm programming but it would void powertrain warranty.
Old Feb 23, 2021 | 7:43 AM
Mike4393's Avatar
[QUOTE=tech2;354353]now sure of your intentions:
These are not cheap.
I did a lot of searching around, dealers are getting up to $680 for a new one.
I'm in an auto related business and even the jobber price was $560.
I've seen them new for as low as $499 online.
However, there's rebuilder in GA that sells them for $199, so this is what I went with UpFix.com
Instructions included in the box show a diagram recommending that you wire-tie it to the brake lines so it no longer absorbs heat from the transmission. The heat is what kills them. They also include a small flat-rate box and address label for the core return.
Shipping was super fast too.
Dominick67
26
Jun 23, 2021 7:34 PM
useme
Cruze
Mar 8, 2017 7:15 PM
ladyharley
Jan 10, 2011 5:08 PM
