Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Timing belt fail?
Old Nov 14, 2020 | 5:06 PM
Carlodi4's Avatar
Default Timing belt fail?
I bought a 2005 aveo 1.6 automatic used. 109k on it. Was getting codes for cam sensor. Got crossthreaded when replacing. Had to take exhaust pulley off to get a tap in straight. So decided to replace timing belt as well. Old belt looked fine. Some fraying on the side starting to show up.
Everything at TDC before I took belt off. Also marked pulleys and old belt. Transferred marks to new belt. The exhaust pulley jumped forward when I took tension off the belt. The intake might have moved, I didn't think it had.
So before I line anything up, spark plugs are out. crank is at its mark, 6:00.
Intake cam is at 4:00. Exhaust cam is at 9:00. Dowel on exhaust cam at 11:00.
I get resistance when I move intake CCW to line up,
It wants to spring back down quickly. I used vice grips to hold it at 3:00. The marks on belt line up with pulleys.
I tension water pump, everything still good. Tighten it down . When I try to turn crank by hand I get to about 7:30 and feel a hard stop. I didn't try to force it past.
I could turn exhaust CCW to line up, but marks would be at 4:00 and 8:00. And the belt wouldn't line up. The marks are 16 teeth apart. Theyd have to be closer together,.
I did a compression test before all this. 170/175/170/180. Car was running ok.
The cams and/or crank have only moved like 29 degrees in either direction since I started.
Any help is much appreciated. This car hates me.
Old Nov 15, 2020 | 7:52 AM
Hope this helps you.
Old Nov 15, 2020 | 2:35 PM
Carlodi4's Avatar
Thx for replying. No I've watched them all. None of them tell you what to do when things aren't going to plan.
I managed to get it turned over by hand. Did all the steps made sure the tensioner was all lined up. I started the car for a minute. Wanted to make sure before I put everything back together.
It ran but all the tension came off the belt..it was about to jump off the pulleys. Wtf??
h20delorean
Oct 8, 2018 7:56 AM
sonimakolo
Sep 19, 2015 1:23 PM
jc323
Sonic (Aveo)
May 1, 2012 1:50 PM
scott11974
Feb 26, 2012 12:54 AM
ButchA
Jan 8, 2007 7:00 PM
