01 2500 Suburban ATC Battery Drain
Old May 13, 2013 | 9:31 AM
mlgunkel's Avatar
Default 01 2500 Suburban ATC Battery Drain
I am on Prince of Wales Island in Alaska (long ways from any dealer) so I have to fix this myself.
The battery would go dead after sitting for a week so I pulled the neg cable and checked amperage between the cable and the battery terminal. After everything goes to sleep I am getting around 450 ma drain that goes away when I pull the ATC fuse.
Can anyone tell me what is on that circuit or where the problem might be? The push button 4wd functions correctly but it is like a module is not going to sleep. Would it be the transfer case control module? Can I just buy one and install or does it have to be programmed once you install it?
Thanks in advance for any help or ideas
Old May 13, 2013 | 1:31 PM
kevinkpk's Avatar
Are you parking it at the chopper pad? I'd suggest if you are working offshore, and having to leave it for a week, is there not 110 ac available? If so, buy a small trickle charger to keep the battery up, do you have a block or dipstick heater?
Old May 13, 2013 | 6:59 PM
mlgunkel's Avatar
I really need to fix the problem instead of working around it
JPTL
Jul 15, 2024 4:19 AM
funnyguyMI
Mar 10, 2024 9:31 PM
bigdaddyviking67
May 14, 2019 10:38 AM
garyd
Apr 24, 2016 3:04 PM
birdxa
Sep 30, 2007 2:45 PM
