02 Suburban w/ 5.3 extended crank at start
Old Jul 29, 2023 | 1:57 PM
  #21
Rednucleus's Avatar
By cycling the switch several times you continue to prime the fuel system; that again makes me suspicious of a problem with fuel backflow valve.
Old Jul 30, 2023 | 5:29 PM
  #22
Sweesym77's Avatar
Is that the FPR you are talking about?? I bought a new one and put it in. Was over $100 and didn't change the problem. Can you be more specific??
Old Jul 30, 2023 | 6:07 PM
  #23
Rednucleus's Avatar
I believe there's a backflow valve built in to the fuel pump so the fuel line stays primed. I have read where people splice one in to the fuel line vs changing out a new pump.
Old Oct 14, 2023 | 6:06 AM
  #24
Sweesym77's Avatar
*SOLVED* It was the fuel pump. There is a check valve in the fuel pump that prevents the loss of fuel prime after shutting off the engine. This is why I could restart the engine right after shutting it off to go in a gas station really quick, but anything longer than that would often result in the delayed start or extended crank as I like to call it.
Mr. Dude with a face
1988 - 1998 (GMT400)
Jun 1, 2022 5:45 AM
Jrock1982
Oct 27, 2018 1:25 PM
tom weston
Feb 10, 2017 8:51 AM
Michael0641
Jul 20, 2015 9:23 PM
Jebar
Nov 17, 2014 8:46 PM
