03 Burban 5.3. Crankshaft pulley needs WD40 every 10 hours to stop from loud screech
Old Dec 21, 2021 | 6:21 PM
Ragnarsson's Avatar
Default 03 Burban 5.3. Crankshaft pulley needs WD40 every 10 hours to stop from loud screech
Old Dec 21, 2021 | 6:23 PM
Ragnarsson's Avatar
Serpentine belt is clean. Upper pulleys look solid. This is just a stock photo so I could show it clearly
Old Dec 22, 2021 | 7:41 AM
repairman54's Avatar
Probably belt tensioner has lost its spring tension. Belts get glazed from slipping also not to mention WD is bad for the belt. Take the belt off and check / spin all the pulleys for play and noise. Check the crank damper for the rubber ring in it failing. If everything else checks good replace the tensioner and belt. They are a ''set''.
DBCooper40
2019+ Silverado (GMT-T1)
15
Oct 5, 2024 8:20 PM
alexandriaeloisa
Sep 29, 2017 12:42 PM
Steelo
Dec 14, 2009 9:35 PM
MH53Jesse
Nov 22, 2009 7:26 PM
snootalope
Aug 24, 2006 10:23 PM
