07 Equalizer settings
Old May 2, 2007 | 5:27 AM
blackzzz's Avatar
Default 07 Equalizer settings
Just got a 2007 Tahoewith single cd / dvd bose system without navigation. Have been unable to figure out how to actually get into the equalizer in order to make some changes. The best I can do is seewhere I can toggle back and forth between talk / manual but can't go any further by getting into manual itself Haven't been able to find anything in any of the literature I received with the vehicle either.
Old May 2, 2007 | 4:22 PM
jmitchell's Avatar
Default RE: 07 Equalizer settings
I have the six disc CD, no dvd, but you should have the same button/dial that looks like a music note to the right of the display. It is the same dial you would use to scroll through radio stations manually. Anyway, push thatmusic note button and the equalizer settings should pop up for the mode you are in.Keep in mind you will have to go through all modes (CD, DVD, XM, Radio, etc.) and individually set theequalizer settings for each one.
Old May 3, 2007 | 1:50 AM
I don't think you get the equalizer with the DVD/Nav setup. At least I don't have it on mine.
Old May 3, 2007 | 8:13 PM
tahoe07's Avatar
He hasdvd and NO nav. Should have the note in center of tune **** as described above.
Old May 3, 2007 | 11:13 PM
kpanza's Avatar
I have the DVD and no Nav, and I don't have any way to customize the settings in the EQ...if I recall, I think the manual said something about only non-Bose systems having the EQ settings?
Old May 4, 2007 | 12:52 AM
tahoe07's Avatar
[align=left]Press the "Note" in center and set the bass, treble and midrange. The EQ button toggles between those settings and thepreset settings (Talk with Bose and theRock, Pop etcif you don't have Bose). See below.. This was cut from the manual under the DVD/CD version of the audio[/align][align=left][/align][align=left]Setting the Tone (Bass/Treble)[/align][align=left]BASS/MID/TREB (Bass, Midrange, or[/align][align=left]Treble): To adjust bass, midrange, or treble,[/align][align=left]press the tune **** until the tone control labels[/align][align=left]appear on the display. Continue pressing to[/align][align=left]highlight the desired label, or press the pushbutton[/align][align=left]positioned under the desired label.[/align][align=left]Turn the tune **** clockwise or counterclockwise[/align][align=left]to adjust the highlighted setting. If a station's[/align][align=left]frequency is weak, or if there is static, decrease[/align][align=left]the treble.[/align][align=left]To quickly adjust bass, midrange, or treble to the[/align][align=left]middle position, press the pushbutton positioned[/align][align=left]under the BASS, MID, or TREB label for more than[/align][align=left]two seconds. You will hear a beep and the level will[/align][align=left]be adjusted to the middle position.[/align][align=left]To quickly adjust all tone and speaker controls to[/align][align=left]the middle position, press the tune **** for more[/align][align=left]than two seconds until you hear a beep.[/align][align=left]EQ (Equalization): Press this button to choose[/align][align=left]bass and treble equalization settings designed for[/align][align=left]different types of music. Your choices are pop,[/align][align=left]rock, country, talk, jazz, and classical. Selecting[/align][align=left]MANUAL or changing bass or treble, returns[/align][align=left]the EQ to the manual bass and treble settings.[/align][align=left]Unique EQ settings can be saved for each source.[/align][align=left]If your radio has a Bose® audio system, your[/align][align=left]EQ settings are either MANUAL or TALK.[/align]
Old May 4, 2007 | 4:22 PM
kpanza's Avatar
Oh yeah, I know I can adjust the Bass, Treble, Fade, etc, but most GMs I have had have always had the various Preset EQs for all the different music genres (Country, Rock, Jazz, etc, etc) - if you have Bose, you either choose Talk or Manual in the Tahoe...I don't mess with it much at all, since I listen to mostly country...
Old May 4, 2007 | 4:48 PM
ZX1100F1's Avatar
Bass, Treble, Fade, Balance (and Mid on some systems) is all you have access to in the user menu.
The old EQ settings were simply pre-programmed variations of Bass and Treble settings that most people rarely used.
Old May 4, 2007 | 10:43 PM
blackzzz's Avatar
Thanks all for your replies...didn't think there was any way to maually mess with equalizer settings other then the treble-bass-midrange thingy but wanted to make sure I wasn't missing something.
jesse06
Aug 12, 2012 5:53 AM
mopar70
Dec 31, 2008 11:43 PM
JeanJean84
Dec 11, 2008 6:17 PM
m0n0x!de
May 15, 2008 1:39 PM
bluffman
Feb 24, 2008 5:24 PM
