07 GM mud flaps
Old Nov 1, 2006 | 7:57 PM
tahoe07's Avatar
Default 07 GM mud flaps
It's time to prepare for winter. Does anyone have pictures of the molded front and rear mud flaps? I really don't like putting them on. If they look too bad I'm gonna get the flatter ones that have the one contour in them and take them off each spring.
I would love to see GM make a conservatively sized molded one that is body color. (Escalades are too big also)
Old Nov 2, 2006 | 12:33 AM
Default RE: 07 GM mud flaps
Here's a not so good pic of rears.
http://www.gmaccessories.net/mccarthychevrolet
I put 'em on mine and they look good. Better than the flat ones IMO.
Old Nov 2, 2006 | 8:52 AM
schorner's Avatar
I don't mind mine because I have a black hoe. Here are a couple pics.
[IMG]local://upfiles/4174/EFDB47A27B0E4A84803A93CD53363DF9.jpg[/IMG]
[IMG]local://upfiles/4174/9045EFCE26F644A298637249A1DD0096.jpg[/IMG]
Old Nov 2, 2006 | 9:35 AM
digdug's Avatar
I ordered some on Tuesday, should be here this weekend. I really didn't want them but with the wider tires I put on the rocker panels and front side of the running boards were getting a little trashed. Am interested to see how they look with the white.
~digdug
Old Nov 2, 2006 | 11:20 AM
biglg's Avatar
schorner,
Are those splash guards the OEM GM brand? Or are they aftermarket?
Old Nov 2, 2006 | 11:24 AM
schorner's Avatar
Those are OEM GM Brand.
Old Nov 2, 2006 | 11:26 AM
biglg's Avatar
Thank you!
Old Nov 2, 2006 | 11:48 AM
tahoe07's Avatar
It looks like you put the rear ones on Too low in the pic. Was that on purpose?
OOPS, optical illusion. Saw the shadow and it looked like a gap between inner edge and bottom of fender.
Old Nov 2, 2006 | 11:54 AM
schorner's Avatar
It was overcast this morning. I saw that too and had to take a second look.
The only issue I ran into was how the front ones fit around the running board. I had to trim the passenger's side flap a little around the running board to get it to seat against the body.
Old Nov 2, 2006 | 11:56 AM
tahoe07's Avatar
Thanks for the info. I'm surprised you had to cut it. They make a specific one just for people with running boards and it doesn't fit right.?
I'm gonna order mine now.
BTW: I have 3M tape to put between body and molded guard. Looks like it might be a good idea with that much overlap of the side of the body.
