07 suburban - remote unlock does not work
The door lock function works. I can unlock right after I locked the suburban. After a few minutes, it will not work unless I first unlock the car with the key. Any clue on what part or module is not working? I already replaced the batteries in the remote. Thanks!
It was called "IP fuse block with internal relay" P/N 15925044
Said replaced due to Doc #1986762.
Didn't say anything on the order about reprogramming.
Professional Mechanic
My truck was doing the exact same thing just the other night. I disconnected the battery for 30 seconds and everything was back to normal. Not sure how long that will last but if it happens again I will investigate further.
goyakpacking
May 9th, 2015 7:51 PM
polpower
August 19th, 2013 10:42 PM
