07 tahoe cabin air smell?
Old Oct 17, 2010 | 5:23 PM
davidh11's Avatar
Default 07 tahoe cabin air smell?
I have a 2007 tahoe that I just bought used and everytime I turn on the A/C it smells kinda moldy our something like a wet dog. After being on for a while it either goes away or I get used to it. Since there is no cabin air filter to change what else can I do? And where does the air come from that feeds the a/c? Thanks in advance for the help.
Old Oct 17, 2010 | 9:40 PM
Welcome to the forum.
The evaporator drain may be clogged and the retained condensate causes mildew before it can evaporate. Once the clogged drain is remedied, there is a product that can be spray into the system that will take care of the smell. There is also a rear evaporator.
Old Oct 18, 2010 | 7:29 AM
davidh11's Avatar
Where would those drains be? I do know that water leaks under the passenger floorboard(outside the vehicle) when the a/c is on so that one in the front should be good but what about the back. Any idea where the air comes into the a/c system?
Old Oct 18, 2010 | 3:12 PM
ousig2408's Avatar
back one will drain right behind the back passenger tire - you can look up and see the small drain
I think it pulls outside air in from right at the base of the front windshield just like nearly every other car.
but unlike most modern cars there is not a cabin filter (as you found out and not good IMO). a good tip is to run the fan for a minute or so before you turn off the truck, with the AC off. what we do is when pulling into our neighborhood I will leave the fan on but turn the AC off, this will help dry off the coil
handstjg
Aug 1, 2020 2:49 PM
justimagination
Jun 11, 2015 8:37 PM
UrbanSuburban
Oct 16, 2014 1:39 AM
