07 tahoe heat blowing out of the driver side vent with ac on
Old May 31, 2011 | 11:38 AM
  #11
allblack's Avatar
I have a similar issue with a 2009 Suburban, warmer air on Driver's side than passenger. If I turn it up all the way to hot and then back down it seems to fix itself.
So what is the final say for this????
Old May 31, 2011 | 3:58 PM
  #12
Official GM Rep
Allblack,
I am sorry to hear that you are experiencing issues with your vehicle. Have you taken your vehicle to the dealership for diagnosis?
Thank you!
Elizabeth, Chevrolet Customer Service
Old Jul 26, 2011 | 1:45 PM
  #13
AaronDemarco's Avatar
My Tahoe is at the deal right now with this same problem. It is the control module under the dash board that sends hot air to the drivers side, while the passenger is blowing cold - repair is costing me $700. I have the same problem in the rear - an additional $800 repair. Bummer of it all, I have the front module replaced 16 months ago and now it's not working again. The dealer only provides a 12 month warranty.
Also an FYI - if you connect your battery, you may get similar symptoms (hot air on side, cold on the other). This will persists for a few days until the car programs itself.
Old Aug 21, 2021 | 5:45 PM
  #14
neta0708's Avatar
Default Driver side blowing hot air
Originally Posted by HoleInOne
I had this problem on my Avalanche after replacing my battery. Here is what I did. Start engine and set drivers side to coldest setting and set passenger side to hottest setting. Turn off engine. Restart engine and reverse the procedure(drivers to hottest and passenger to coldest). Turn off engine. Restart and set to normal settings. Don't ask me why but it worked for me.
It worked for me too… Wow
Old Aug 22, 2021 | 10:05 AM
  #15
Cusser's Avatar
This happened on our 2005 Yukon as well. Since an independent shop had charged about $400 to replace the actuator on our 1994 Suburban, I did the 2005 repair myself (after setting it manually to cold and disconnecting the electrical harness for a year), used a Dorman aftermarket actuator. The 2005 Yukon had 3 such actuators, under the dash.
Old Sep 6, 2021 | 3:30 PM
  #16
jeremyleff's Avatar
This worked on my ‘13 Tahoe after the battery died. Thanks for the tip!
Old Jul 28, 2023 | 4:06 PM
  #17
danster1993's Avatar
I had to do it twice but it worked for me!! Your a genius
Old Jun 9, 2024 | 1:35 PM
  #18
ChaoticChevy's Avatar
I have an 07 tahoe LT. my issue is the passenger side everything else works fine. i replace everything that could be replace actuator, Control unit and still the same problem. Even manually moving the blend door did nothing for the passenger side. please help.
Old Jun 24, 2024 | 11:17 AM
  #19
mk3supraholic's Avatar
could be refrigerant level is low. Have it checked. The evaporator only cooling 1 side when low is common.
Old Jun 27, 2024 | 12:24 PM
  #20
wjonesasu's Avatar
Originally Posted by adamant
Heat is blowing out of the drivers vents with the ac on. Passenger side and back is fine. What's the deal? I am not under warranty no more but it has been in for this while it was under warranty.
If it starts out cold then turns hot this will work
jmarkv
Jan 24, 2012 8:21 PM
C.Hicks
Aug 25, 2011 5:11 PM
clayman
Apr 19, 2009 7:55 PM
