07 Tahoe - how to connect aftermarket DVD audio output to factory radio
Old Jan 6, 2007 | 4:44 PM
haidangwa's Avatar
Default 07 Tahoe - how to connect aftermarket DVD audio output to factory radio
I just installed an aftermarket overhead DVD in my '07 Tahoe LT3 with Bose system, XM,and 6-disc in-dash CD changer (no nav or factory DVD option). The overhead DVD is a Kenwood LZH-100W. The DVD player works great with the IR headphones, but not so great with the FM transmitter -- reception on my factory radio has lots of interference. What is the best way to connect the DVD player's audio output to the factory radio, if possible? Is there a way to improve the FM reception without plugging the DVD into the factory radio?
Thanks,
haidangwa
Old Jan 7, 2007 | 1:38 AM
Default RE: 07 Tahoe - how to connect aftermarket DVD audio output to factory radio
Do you have a choice of several FM freqs or are you stuck with just one? If choice available, might try another freq as the current one might be close to a local station. If that doesn't work, try their website for tech help or FAQs.
Old Jan 15, 2007 | 4:50 AM
haidangwa's Avatar
I've tried all the frequencies available. Sometimes, the reception is good, sometimes not. Are there any adapters available for the '07s yet that would allow me to connect the audio line output from the DVD directly into the radio? I know there are adapters for the earlier models, but none I've seen are specifically for the '07s. Without taking the factory deck out and looking, I don't know what connection options I have available. For example, other adapters would take the place of an external CD changer, but since I have mine in-dash, I don't think I can use that as an option. The factory radio does have an auxiliary audio input on the front (1/8" connector), but that wouldn't be a clean look to connect the DVD to that input.
Old Jan 15, 2007 | 12:28 PM
biglg's Avatar
Call JPcustoms.com They will probably be able to give you the information you are looking for.
Old Jan 16, 2007 | 1:44 PM
SWRidin's Avatar
You also might want to call Kenwood. I had a Sony dream dvd (aftermarket) installed in my old Silverado. I called Sony and found the cord I needed to do the direct line. Sony sold it as an additional accessory. Right now I have an Audiovox in the 07 Tahoe. I haven't looked into a direct line yet, this post just reminded me.
Yeah, the FM Modulator channels will be poor, especially if there is already a local radio channel using the same frequency. Sometimes changing channels helps, but in most cities all the channels are taken. I don't like to use the FM Modulator because the low quality forces you to turn it up louder than usual and I don't want the distortion to damage my speakers. Usually the kids wear the wireless headphones and I listen to the XM. This has been working fine for us, but it would be great to run a clean direct audio line for when we do want surround sound in the cab.
Old Jan 16, 2007 | 6:05 PM
xclusive's Avatar
you should have an audio output on your overhaed and if you do you can plug it into the aux input on the front of your factory radio. if you dont have a aux input in the front of your factory radio you can always by a wired fm modulator which cut off all fm frequencies when turned on and is a lot more reliable than the fm transmitter that is built into your overhead.
Old Jan 17, 2007 | 7:48 AM
astig00's Avatar
ORIGINAL: xclusive
We used the input in front of the radio. Worked better than the modulator.
Old Jan 17, 2007 | 9:16 PM
haidangwa's Avatar
I thought about using the factory radio's front aux input with the DVD's audio output. I've used the aux input when I used to tote my laptop along for the kids to watch movies, and the sound is great. For this overhead DVD, though, I'd like a clean look. Thanks, all. I'll look into JPcustoms. BTW, does P.I.E. make any adapters for the '07's yet?
mrjimmys2000impala
Jul 19, 2015 9:04 AM
mrjimmys2000impala
Site Feedback
Jul 18, 2015 4:04 PM
scumpoozie
Jun 10, 2013 7:31 PM
LinuxMan
Jun 27, 2009 3:13 AM
awkenney
Dec 28, 2005 5:15 PM
