12v outlet overheated started fire?
Old March 22nd, 2012, 2:36 PM
  #11
slw210's Avatar
The Ford Cruise Control fires were not electrical in nature. The claim is, brake fluid leaks onto the switch (it is mounted on the master cylinder) and catches fire.
Thanks for reminding me though, I need to check for the new switch on my '96 Bronco. Interesting enough, I never found where any Broncos caught fire due to this same switch.
Old March 23rd, 2012, 8:13 AM
  #12
SabrToothSqrl's Avatar
Default rubber flapper
there was a rubber flapper type device that was between the brake fluid (acidic) and a hot circuit... so when the rubber would wear out, it could cause a fire.
the rubber flapper design is stupid on it's own, but combined with a circuit that's on while the vehicle is OFF AND PARKED is just retarded...
here's more info
Cruise Control Fire Recall Expanded To Ford's Largest Ever
Hey; let's put in a fuse, but not bother to replace the POS part. no wonder ford sucked back then.
today, they took the feedback of their new My Ford Touch and actually, FOR FREE, upgraded all the old ones with 2013 programming....
Old March 24th, 2012, 5:44 PM
  #13
RacerX's Avatar
I tried it, I think the story is half bogus. In my G20 if the 12v circuit is closed too long it will blow the radio fuse, 25 Amp. So I m thinking her charger went looney and it was what started the fire. I leave my laptop on overnite sometimes and in the morning the panel is blazing hot. I unplug it and let it run off of battery power and then it seems to cool down.
I know SONY had a recall a few years ago about their Li+ batteries and a fire hazard.
Old March 25th, 2012, 10:40 AM
  #14
fredrich03's Avatar
Default On Star??
A local guy with a '10 Suburban was having trouble with his battery running down overnight. It had been at the dealer off and on for about a month and the service manager concluded it was the On Star module.
The module was getting hot to the touch. Customer does NOT subscribe to O/S.
Of course, On Star denied their module was at fault, so a tech from GM came to check it out and while he was diagnosing, the On Star advisor came on (by itself) and asked if help was needed.
On Star module was replaced and fixed the battery run-down problem.
So, if an O/S module will run a battery down overnight, I believe it could also cause a fire.
Now, look at the pics in the original post again. Looks to me like the fire started in the O/S module area, doesn't it??
Old March 26th, 2012, 8:09 AM
  #15
Default tracking
perhaps he didn't opt out of the illegal tracking and voice monitoring
'Shameless'! OnStar tracks users' driving habits even after they quit service; it must stop: Schumer - New York Daily News
OnStar plans to track users even after disconnecting service
Yes this is old news, and they claim to not do it any more, but can you really trust a company that would even think of doing this? I sure as hell don't.
Old March 27th, 2012, 6:04 AM
  #16
RacerX's Avatar
Yet another reason for replacing the factory radio.
Lady
June 29th, 2008 10:00 AM
chevy3500
June 4th, 2008 2:56 PM
zero lash
April 26th, 2008 8:30 AM
BIGDAD
June 26th, 2007 3:49 PM
gargamel343
March 14th, 2007 12:58 PM
Quick Reply: 12v outlet overheated started fire?
