1995 Tahoe Problems
Old Jun 17, 2009 | 11:47 PM
gruņis's Avatar
Default 1995 Tahoe Problems
Hi,
i just bought a 95 2dr tahoe, i´ve had it for a couple of weeks and have had a series of problems that i´m sure have bee suffered by someone else out there:
1. Sometimes, the engine light suddenly applears and the shifting becomes strange, hard, and fourth gear does not seem to engage, if i stop the car, turn it off for 10 seconds, the problem dissapears... any ideas?
2. When i turn the A/C blower towards the feet or the front glass, works great, but whei i put it in the position in which it´s supoused tho blow air in my face,.. he air does not come out, the blower works, bt no air...
3. When i engage the 4X4 and start going offroad, i get a scary sound when turning tactac tac, going istraight no problem, only turning
Thanx a lot for the help
Old Jun 18, 2009 | 5:53 PM
suzuki-guy's Avatar
The noise when turning sounds life front wheel bearing, or cv halfshaft. Lift the front of your vehicle up and see if there is any play in the tire with your hand at 6 and 12.
Old Jun 22, 2009 | 8:22 PM
Welcome to the Chevrolet Forum.
The A/C problem sounds like the position divertor door is stuck or not working. The defrost/floor is the default position on most systems in case of failure to keep the W/S clear and your feet warm.
Old Jun 22, 2009 | 10:20 PM
MDTAHOE's Avatar
Professional Mechanic
You need to check the vac supply for the heating and ac under the hood, it will be the only vac line going through the firewall. It is in default 95% of the time the problem is under the hood. You need to have the computer scanned to see what codes are present.
Old Jun 23, 2009 | 2:47 AM
Koffietje's Avatar
Problem 1 : seems like the transmission builds up too much pressure , because of the heat. You might want to check if there is ENOUGH and NOT TOO MUCH oil in your transmission box. Also check the colour of the transmission fluid (it should be red and there should be no particles in it).
the tactactac, could be 2 things :
1) your powersteering pump which has a worn out belt
2) your front differential that is about to say" F. it ...I'm out of here"
(Could of course also be your little son, playing in the back of the truck with a toy machine rifle, who sees a great opportunity of shooting at the imaginary enemy while taking a turn. But just for now, lets skip that possibility).
Old Aug 20, 2009 | 6:28 PM
gruņis's Avatar
Default More Help
I cant find the vac supply... sorry, could you give more directions on how to do it? you have a picture??
Thanx a lot
Old Aug 20, 2009 | 7:49 PM
MDTAHOE's Avatar
Look around it will be the only line going through the firewall. Look around the area where the heater hoses and ac lines go through. There should be a vac diagram on the hood.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
dcfd470
May 2, 2014 7:27 PM
FRENCHEVY
Feb 27, 2010 5:15 PM
SabrToothSqrl
Feb 10, 2008 8:48 PM
