1997 burban fuel issue...
Old Sep 23, 2010 | 8:24 PM
chev1989's Avatar
Default 1997 burban fuel issue...
It was running when it died and will only start with starting fluid. The pump comes on with key for the 3 second prime like it is supposed to,the in-line filter is brand new and the pump was changed about a year ago,just put in a new distributor and ignition module and I am at my wits end with this please help if you can......
Old Sep 23, 2010 | 8:59 PM
check the fuel pressure, may need to replace the fuel regulator
Old Sep 23, 2010 | 9:01 PM
chev1989's Avatar
where do I check the pressure at....
Old Sep 23, 2010 | 9:17 PM
should be right on the fuel pipes going to fuel meter body...
unscrew the protective cap and install the pressure gauge....
Old Sep 23, 2010 | 9:35 PM
crbav8r's Avatar
What should the fuel pressure be at before start, and after shutdown? Should there be any bleed down, and how much?
Old Sep 23, 2010 | 10:02 PM
chev1989's Avatar
Is there a special tool for testing the fuel pressure using that spot you told me about (under the protective cap) or just any "pressure tester" also I am looking thru my chilton right now and I cannot find where it says what the fuel pressure is supposed to be. Can I test the pressure during the 3 second prime mode with the key in the "ON" position or does the truck need to be turning over when I test? By the way, thank you for your time!
I'd guess at least 45 psi, not sure about leakdown.
chev1989: The fuel port will look like a Schrader fitting similar to an A/C port.
Old Sep 23, 2010 | 10:06 PM
chev1989's Avatar
I found the fuel port I just dont know what to test it with or what status the fuel pump needs to be in during the test...
Old Sep 23, 2010 | 10:14 PM
You need a FI fuel pressure gauge. You can check with the key on, engine not running.
Old Sep 24, 2010 | 6:59 AM
96 hoe''s Avatar
I had a similar problem. I had to "prime" the fuel pump 5 or 6 times to get it to start. I only had 55 psi at start up and I read somewhere that 75psi is needed. Becareful with that starting fluid tho, dont wanna burn up a piston do ya?
