1998 suburban wont start (video inside)
Old Apr 1, 2012 | 3:17 PM
kc_burban's Avatar
Default 1998 suburban wont start (video inside)
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid1145.photobucket.c om%2Falbums%2Fo519%2Fkc_burban%2FVID_20120401_1400 06.mp4">
http://s1145.photobucket.com/albums/...401_140006.mp4
Its a 98 GMC suburban with 5.7. Never had an issue starting before last night. all of a sudden coming out of the gas station it just stopped wanting to start. I have no idea where to even begin. Im hoping this video gives you guys better insight then me trying to describe the sound. Ive tried jumping it with no luck.
Thanks for the help
Old Apr 1, 2012 | 3:29 PM
Welcome to the forum...
Sounds like the starter is spinning but not engaging the fly wheel... sometimes a whack with a mallet to the starter might get you going for a time or two...
Old Apr 1, 2012 | 3:37 PM
kc_burban's Avatar
Thanks for the welcome. I appreciate it. How difficult is it to replace the starter and the fly wheel in one of these bad boys? And any DIY
Old Apr 1, 2012 | 3:50 PM
You would only need to replace the starter if that is indeed the problem... there is no need to replace the flywheel unless its damaged.
Replacing the starter is pretty straight forward...
Disconnect the battery as the cable to the starter is live all the time...
there are typically 2 bolts holding the starter in, there may be some shims that will need to be re-used...
disconnect the battery cable and the starter cable connection and re install new starter...
Old Apr 1, 2012 | 4:25 PM
kc_burban's Avatar
Thanks again.
Old Apr 1, 2012 | 4:29 PM
kc_burban's Avatar
What brand starter would you recommend?
Old Apr 1, 2012 | 5:16 PM
I personally use OEM or AC/Delco parts but your budget will dictate what you put into it... Consider a re-manufactured OEM unit, that will give you the reliability of the factory unit but at a better price...
Once you pull the starter, many automotive places can check them, plus most are going to require a core...
Old Apr 2, 2012 | 6:44 AM
shamrock246's Avatar
I've had good luck this site and so have of other people on anther forum i'm a member of get one of the PMGR ones
Starters, Alternators and more for Cars, Trucks, Tractors and ATVs
Chevrolet Forum News
Nov 20, 2014 2:08 PM
Focusrite
Jan 11, 2014 1:49 PM
chevelle74us
Sep 16, 2013 7:39 AM
elsoso
May 21, 2013 9:43 PM
jasper123
May 1, 2008 10:22 PM
