1999 Suburban Fuel Tank Hose T Style Connector Broken
Old Dec 15, 2023 | 9:46 PM
Agrandis's Avatar
Default 1999 Suburban Fuel Tank Hose T Style Connector Broken
Hey everyone. I was recently given the 99 Suburban I drove in high school which is in need of some restoration and fixing. I found the fuel pump was out so I dropped the tank to replace it. During that process, the T-style connector on the vapor line broke (not sure on name but it’s the one hose that does not connect to the sending unit). I’ve attached a picture of the part I’m talking about because I’m having a hard time finding anything about it or the lines it connects. What is this part called so I can replace it and get the engine back up and running? The plastic was really brittle so I’m sure it needed to be replaced anyway. I appreciate any help!
T-Style Connector
Connector for this line
Old Dec 16, 2023 | 7:46 AM
Welcome from Florida. You can go to any auto parts store and they will have T connectors of varying sizes. They are inexpensive and no need to go to the dealer and get it from them at a much higher price.
Advance Auto Parts: Car, Engine, Batteries, Brakes, Replacement, Performance & Accessories
Old Dec 16, 2023 | 8:05 AM
Cusser's Avatar
I've also found small T-connectors in both plastic and brass at the neighborhood Ace Hardware (small hose barbs at each end). Even Amazon lists them.
Old Dec 30, 2023 | 9:00 PM
Agrandis's Avatar
Thank you all for the help. Got that piece replaced, new pump and filter installed, and the engine started right up. Other than idling a little rough, it was like it never sat for years.
Now when I start it, a little flame drops out under the engine while the starter is running. After it drops, the engine runs. Obviously that’s a hazard but fixing my Suburban is worth it to get it road worthy again.
Old Dec 31, 2023 | 8:55 AM
Cusser's Avatar
A real flame or a spark ?
Old Jan 2, 2024 | 9:16 PM
Agrandis's Avatar
I’m not 100% sure. I was able to get this one video of it happening but haven’t been able to reproduce it now that I have a fire extinguisher next to me.
Old Jan 3, 2024 | 8:33 AM
Cusser's Avatar
I don't like that ! If it happens again, I'd consider replacing the starter or have a mechanic look at it.
ChevyMonster
Aug 22, 2020 9:40 PM
watersteps
Nov 10, 2019 5:08 AM
BACNBLACK
Jun 2, 2009 6:21 PM
b45701
Apr 1, 2007 2:11 PM
