20" tire pressure
Old Nov 3, 2006 | 5:51 PM
addkev's Avatar
Default 20" tire pressure
I did a search could not find the answer.
What is the proper tire pressure for the '07 OEM 20" wheels?
Old Nov 3, 2006 | 6:11 PM
Default RE: 20" tire pressure
It's on the driver's door sticker. Without looking, I think it's 35 psi.
Old Nov 3, 2006 | 6:42 PM
addkev's Avatar
ORIGINAL: 73shark
Mine came with 17's, just wanting to make sure I have the right pressure in my new 20's
Old Nov 3, 2006 | 6:55 PM
Dash's Avatar
My LTZ came with the 20's...the door post label say 32....the dealer had put in 40.... I though the tire pressure guage iin the info center was wrong but I checked it. I let out 8lbs and now have 32 at cold reading.....ride is much better
Old Nov 3, 2006 | 8:07 PM
maynard_tim's Avatar
On the tire is says with max load maximum of 44 PSI. I run 37 in all of mine, steers a little better, than when running 32.
Old Nov 3, 2006 | 8:12 PM
Dash's Avatar
Is that 37 when cold? I notice the onn the info center that the pressure rises when warm about 5 psi.
Old Nov 3, 2006 | 8:14 PM
tahoe07's Avatar
My door says 32. I run 35.
I let them get to 32 cold reading (as it got colder this fall) when I checked it they ran about 37 on the highway with that setting. I'd be curios to see what your running temp was when you had them 40 cold.
Old Nov 3, 2006 | 8:21 PM
Dash's Avatar
I am not sure what you mean by running temperature. It was 55 degrees outside. And the car had been sitting over night.
Old Nov 3, 2006 | 8:23 PM
tahoe07's Avatar
Pressure should be checked cold -After sitting or being driven a very short distance.
Mine is about 32 cold and once on the highway awhile the sensors read about 37.
No biggie-just curious--- I guess if a higher pressure creates less rolling resistance it may not raise as much as mine did...so 5psi or less I suppose.
Old Nov 3, 2006 | 8:25 PM
Dash's Avatar
Thats what I am seeing on mine. I never checked the warm psi when they read 40 cold, I immediately reduced them to 32.
