2002 Suburban Fuel Pump Noise
I've only owned my 02 Suburban 2500 w 8.1 for a few months, so I'm still getting used to the sounds it makes. I use it mainly for towing our travel trailer. I've noticed lately after towing for a bit, the fuel pump becomes pretty loud and whines. I'm going to try and post a short video clip of the sound. Fuel level is rarely below 1/4 tank and it will make the noise on Full tank too. I know these pumps make noise, but also that they fail. I've got 108,000 miles.
Just trying to decide how urgent it is that I replace the pump and filter or if this is normal. How to replace is another post I guess.
Thanks!
Thanks!
The noise may well be because the fuel filter is clogged and making the pump work too hard to push fuel thru it. I also always consider fuel level at 1/4 to be empty. The pumps in the tank like lots of fuel there to keep the pump cool. Replace the filter and see if noise diminishes, otherwise, do the pump as well. I always like to do the fuel pump relay when I do a pump and filter.
PNW NBS Z71 (November 9th, 2020)
PNW NBS Z71 (November 10th, 2020)
Is there anything else you can think of that you would suggest?
I recently bought my 2005 Z71. I did not get any records with it. Having been in the industry for many years I wanted to get to a baseline. I have done front and rear brakes and rotors and park brake shoes, all belts and tensioners and idler, ALL fluids, all cooling system hoses, all 4 oxygen sensors, did all 4 rear axle locating arms because found one lower one was bent from some idiot using a floor jack on it, new tune components, no fuel filter because the filter is in the tank, new third brake light, new outside driver's mirror, new thermostat and new trans filter and seal, new transmission cooling lines, new air filter......etc. Will get it where I can depend on it and go from there.
Smayday
December 10th, 2019 9:59 AM
gardshooter
June 8th, 2017 8:08 AM
