2002 Suburban Problems
Old May 11, 2012 | 2:49 PM
kashander's Avatar
Default 2002 Suburban Problems
I have a 2002 Suburban 5.3L that has stopped shifting into gear. You can depress the brake and physically move the shifter and it indicates that it is shifting but it won't actually go into gear and it won't move. It started at 50 MPH on the highway and it just stopped turning the engine. RPM goes up but the wheels don't turn. I'm just wondering if anyone could give me some advice on where to start or what might be wrong.
Thanks
Old May 11, 2012 | 7:24 PM
EinST's Avatar
Welcome to the forum. I take it that it does engage the parking pawl when you move the shifter into Park? Then, something's gone terribly wrong with the hydraulics (valve body, failed pump?). Check the IGN 0 fuse in the driver side I/P fuse block and then tow it in if not that.
Old May 14, 2012 | 4:13 PM
hicksvilleshick's Avatar
something in the transmission has gone horribly horribly wrong.
:chug:
Old May 14, 2012 | 9:56 PM
MDTAHOE's Avatar
Professional Mechanic
Problem is internal in the trans or the transfer case. Pull the pan off the trans to see if there are any parts laying in the bottom.
Old May 18, 2012 | 10:21 AM
johntaps's Avatar
Former Sponsor
That would be a 4L60E or a 4L80E in your truck.
Either one was pretty complicated transmission to diagnose...all electronic.
I would guess valve body failure or another major component since it failed at 50mph.
Unless of course the transfer case was shifted into neutral but I am guessing you checked that ;-)
I think towing to a transmission shop is in order.
Last edited by in2pro; May 18, 2012 at 12:36 PM. Reason: no edit made.. saw the sponsor link :)
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
bigEd12
Aug 19, 2015 12:50 PM
mwehrste
Dec 29, 2014 11:19 AM
SASS19102
Jan 21, 2014 6:30 AM
Henry59
Apr 11, 2012 10:41 PM
