2004 Tahoe Side Marker Lights
Old Jan 16, 2020 | 9:00 PM
retsub's Avatar
Default 2004 Tahoe Side Marker Lights
I need to replace both front side marker bulbs. How can I easily make them work with the turn signals for some added safety when seen from the side view. Thanks. *BW*
Old Jan 17, 2020 | 7:04 PM
retsub's Avatar
UPDATE; I'M VERY SURPRISED that NO ONE caught onto this mistake !!! After I spent hours online and found out the answer to my question and tracing wires to try it all out and scraping enough insulation to connect alligator clips to the wires to try the new method I first replaced both burned bulbs and turned them on to try out firstly. DUMMY HERE had forgotten they worked the very way I was looking for already from the factory since day one !!! The turn signal and side marker lamps took alternate flashes just like I wanted all the time !!! It really is hard to admit a mistake but I am. So, "IF" you think you have a problem please be sure you really do before you start to fix it. *BW*
ky1duck
Feb 9, 2015 8:34 AM
hazard2600
Feb 21, 2014 7:47 AM
potatoheadman
Jun 29, 2013 1:06 PM
boneskeys
Jul 31, 2011 12:27 PM
nukeflash
Jan 20, 2008 2:51 PM
