2004 Tahoe Z71 Emerg Brake Light stays, chime stay on Constantly while EB
Old Feb 22, 2013 | 4:17 PM
  #11
JWRed's Avatar
I feel Shark is on to something. I had a similar problem in my 04 2500 around June 2012. I would do this each time I released the brake.
Finally, the cable connecting the release broke. It seems the braided cable was worn-out and preventing the break from fully releasing. I replaced the cable and have not seen the warning since then.
Something to consider!
JW
Old Feb 23, 2013 | 3:09 PM
  #12
myspacethirdbase's Avatar
Talking
Happy Dance here! After troubleshooting and asking for help on this forum, the problem was solved. It was the Parking Brake switch, it broke off at the Grounding piece and I had it replaced for under $100.00 at the dealer. Thank you so much everyone!...now onto the cluster.....
Old Feb 25, 2013 | 7:46 AM
  #13
Glad you got it fixed.. what issue are you having with the cluster ( assume you mean the interment panel) ?
Old Feb 26, 2013 | 11:33 AM
  #14
Hi, I posted about my instrument cluster problem in a different thread on this forum. With the help of this forum and YouTube, I got it out, gently tore it apart checked all the leads, soldered a few leads that I thought might be amuck...put it back together...but the Gear Selection continues to fade in and out.....PRND321...So I think I need to send the cluster off to someone more of an expert..I tried and am thrilled with the knowledge I learned from here and YouTube!
Old Jun 2, 2015 | 12:06 PM
  #15
kinneyed's Avatar
my solution was to simply grab onto the emergency brake pedal and pull it up
Old Jul 5, 2017 | 12:47 PM
  #16
Terry500's Avatar
Smile Somewhat similar issue on 2015 Malibu
Sometimes, even when the parking brake is released, I'll get the chime for a while on the Malibu. No warning light of any kind appears on the instrument panel. I believe what may have started this is I've driven for short distances with the parking brake on and not realized it. Then, I'll release it. So now, sometimes the chime goes off even when the parking brake is released. I've tried to set the parking brake and release it several times to see if that fixes it. That seems to work. If the problem continues, I may have to bring the car in for some work.
89scottsdale
Aug 22, 2022 10:07 PM
MasterPonAtari
Jan 13, 2015 9:54 PM
jrsavoie
Oct 2, 2012 10:50 PM
tunnelhillthrill
Nov 26, 2011 8:06 PM
Soah
Feb 23, 2008 10:25 AM
