2005 Suburban Ball Joint Question
Old Apr 16, 2020 | 11:17 PM
Luis A.L.'s Avatar
Default 2005 Suburban Ball Joint Question
Hi
I have a 2005 suburban with a 2inch leveling kit, I noticed the upper ball joints are all busted, the guy at the auto parts told me I needed to replace them with adjustable ball joints
how true is this?
Old Apr 17, 2020 | 9:35 PM
the oem ball joint in the upper control arm is not meant to be pressed out; the upper control arm must be replaced. if you have aftermarket control arms they may allow ball joint replacement; pressing in the new joint into the control arm.
adjustable ball joints are for trucks with no camber adjustment. your truck has caster/camber adjustment eccentrics on the upper control arm. if you can't get the caster/camber in spec due to the lift kit...aftermarket control arms are available that correct for the lift and allow adjustment in the in spec range.
from the alignments I have done on 2 inch leveling kits... the alignment will still be in spec with the stock control arm.
to correct your worn ball joints...replace the upper control arms and then get an alignment.
2KBurb
Dec 31, 2024 8:14 PM
crystallee3
Oct 18, 2013 10:05 AM
BigDaddyO
Oct 18, 2011 11:09 AM
runningjalapeno
Jan 24, 2011 2:31 PM
Mr.Cale
Feb 7, 2010 7:07 PM
