2006 lt suburban cluster light
Old Nov 6, 2010 | 12:53 PM
qwfx's Avatar
Default 2006 lt suburban cluster light
hi crew my cluster light the left side is gone?
does the cluster has bulbs to replace individually or I have to buy the new cluster, I was told that i can not just replace bulbs, (mechanic told me)
any feedback please
Old Nov 6, 2010 | 4:36 PM
the document I have the 2006 Tahoe shows this info... can always take a peek at it and see if you can access the bulbs...
2006 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Document ID: 445213
Instrument Cluster Bulb Replacement
Removal Procedure
Important: This procedure calls for the replacement of incandescent bulbs only. The light emitting
diodes (LEDs) are not replaceable individually. If LED or soldered-in incandescent bulb replacement
is needed, send the cluster to an AC Delco Service Center. Refer to Instrument Cluster
Replacement .
1. Remove the instrument panel (I/P) cluster. Refer to Instrument Cluster Replacement .
2. Unclip the I/P cluster rear cover plate by prying gently on the tabs with a screwdriver.
Document ID: 445213 Page 1 of 3
3. Remove the rear cover plate from the I/P cluster.
4. Remove the bulb and base assembly by turning the bulb 1/2 turn counter clockwise and
pulling outward.
5. Remove the bulb from the base by pulling outward.
Installation Procedure
Replacement .
Document ID: 445213 Page 2 of 3
1. Install the bulb to the base.
2. Install the bulb into the cluster by inserting the bulb and base assembly and turning the bulb
1/2 turn clockwise.
3. Carefully snap the rear cover plate to the I/P cluster.
4. Install the I/P cluster. Refer to Instrument Cluster Replacement .
Document ID: 445213 Page 3 of 3
Attached Thumbnails 2006 lt suburban cluster light-pic-1.jpg   2006 lt suburban cluster light-pic2.jpg
Old Nov 6, 2010 | 4:59 PM
qwfx: Welcome to the forum.
Let us know how it works out. Even if it is a soldered in component, I'd give it a try.
tony72
Nov 17, 2014 7:11 AM
Stevo99c
Nov 25, 2010 2:48 PM
barr0691
Aug 12, 2010 11:16 AM
brenthans
Jan 1, 2009 2:31 PM
estolano
Jan 23, 2008 9:15 PM
