2007 chevy suburban power lift gate problem
Old Sep 23, 2013 | 6:58 PM
  #31
loosid's Avatar
Default just ordered latch 190 on hanske website.. 10/13
just ordered the lath through the gm parts website link that hanske punched in. will install and update with update. also had taken it to guaranty chevrolet in santa ana, ca 1 year ago to have the rear unit reprogrammed in case that was the issue. it did not solve the problem. that was after i bought and installed a motor (was not the problem). was told by the dealer that the actual issue per the codes was the latch. never cared enough to get around to purchasing it, since the rear liftgate works fine manually. but got tired of other people, valets and car wash people push the button to kingdom come with no results. ha. will post if this fixed the problem. by the way, guaranty chevrolet gave me a quote of 595 to fix my problem. ...
Old Oct 4, 2013 | 9:48 PM
  #32
loosid's Avatar
Thumbs up update to liftgate issue
PROBLEM SOLVED. BOUGHT THE 170 POWER LIFTGATE LATCH FROM THE http://www.newgmparts.com/partlocato...?siteid=213815 GM PARTS WEBSITE. ABOUT190 WITH TAX AN SHIP. PARTIALLY REMOVED LIFTGATE PLASTIC COVER, REMOVED 3 BOLTS AND 1X PLUG. REPLCD W/ NEW PART. RELANDD BOLTS. 17MINS TOTAL FROM START TO FINISH. FIXED MY PROBLEM. MIND YOU, GUARANTY CHEVROLET IN SANTA ANA GAVE A QUOTE OF 570 FOR PART AND LABOR TO FIX MY LIFTGATE NON OP PROB. DEALER IS SUCH A RIP OFF. NO RESETTING OF BACK COMPUTER NEEDED. PLUG AND PLAY. 2007 CHEVY REAR LIFTGATE, NON OP/ DOES NOT OPEN. PROBLEM SOLVED.
Old Jan 19, 2014 | 5:25 PM
  #33
hjprice07hoe's Avatar
Any suggestions if I replaced the latch and while there is actually now some movement (will not open on its own at all, but when open will close about 1/3 of the way and stop) it still isn't working?
Old Nov 6, 2014 | 3:12 PM
  #34
Pax Man's Avatar
Part Number for the latch?
Old Nov 6, 2014 | 3:17 PM
  #35
Pax Man's Avatar
I found it...thought I would post for all:
  • <label>Manufacturer:</label> GM
  • <label>Part Number:</label> 13581405
  • <label>Part:</label> Liftgate Latch assembly
  • <label>Part Notes:</label> lift gate door w/pwr lift gate
Old Nov 7, 2014 | 10:59 AM
  #36
Welcome to the forum Pax Man, and thanks for the follow up on your finding the parts
Old Feb 16, 2015 | 11:27 AM
  #37
tomblumens's Avatar
I am experiencing the same issues with my 2008 Tahoe's back tailgate. Did replacing the GM 13581405 Liftgate Latch resolve the problem?
Old Feb 24, 2015 | 7:53 PM
  #38
martin.karl's Avatar
Default similar problem with my 07 suburban
My rear power lift gate works sometimes. remote, button on overhead console, even with the rear handle button. lights will flash, you hear the sounds, but gate does not lift. sometimes it works perfect! seems to have a mind of it's own. just a major problem when we need to load or unload groceries, stroller, etc...
glass opens fine, but some items are too big or bulky to move in and out through the glass.
HELP!
when it does work, again... works perfectly fine!
on a possibly related note (electrical issue, maybe) after reversing and placing back in drive, i'll notice the parking sensor lights (on the rear passenger side pillar) will have a flashing red light when driving forward after reversing out of a parking spot. it'll keep flashing while driving. i've found that while moving forward, placing the transmission in neutral, then back into drive, it'll stop the red light from flashing.
while the light is flashing, if anything approaches the rear bumper (even with the gear still in a forward drive gear) the sensor will beep at me letting me know something is near the rear bumper.
any suggestions?
Old Feb 26, 2015 | 6:58 PM
  #39
loosid's Avatar
Default power lift gate
yes.. the latch did work. i incorrectly replaced the motor. $300+ from dealer. i swapped it out myself. no dice. i read it could be the latch. ordered one from same website stated earlier in post for my exact model. 10 minutes with out any extraordinary tools and i was done. worked like a charm.
Old Apr 8, 2015 | 7:54 PM
  #40
Val26's Avatar
Default Replacement Latch Worked!
Ordered the replacement latch assembly, installed latch and wala...power liftgate is now working! Thanks for all the help😊
