2007 Climate Control Issues
Have a 2007 Tahoe with automatic climate controls. The front air works great for about 1 to 2 hours before air stops blowing out of any of the vents. We I turn the fan to high the blower is running at a high speed but still little to no air from the vents. The rear air works just fine without any problems. Can turn the A/C off for about 20 to 45 minutes and once I turn the A/C back on, it will work for another 1 hour or so before I have to repeat the process on long road trips.
I have already replaced the blower moter, blower resistor and cycling switch.
Any ideas on what's next?
Not sure why you replaced the blower motor if it was still blowing air. If the rear A/C is working, then it can't be the cycling switch and all the resistor does is provide a voltage drop for the different speeds.
Plus same questions as STS above.
@SabrToothSqrl
You are correct, the blower still blows at the different speed rates based on the HVAC control settings but there is NO air flow from any of the vents in the front cab area of the truck. (dash vents, floor vents and defrost). Have tried all vents settings.
Nothing seems disconnected. Tonight, I will pull everything apart and check for any blockage. It is very weird. Like I stated earlier I can turn the A/C off for about 30 minutes and it will start back working without any problems for about another hour.
Check the blower wheel to make sure that it is not loose on the motor shaft.
With the blower on high, stand outside on the passenger side near the intake at the base of the windshield and listen for any airflow.
Edit: Since it seems to work and then quits makes it sounds like something other than a blockage.
flintlock
Nov 12, 2010 1:51 PM
