2007 Suburban 2500 6.0 4L80E top bell housing bolt
Old Nov 7, 2021 | 7:36 AM
racerx37335's Avatar
Default 2007 Suburban 2500 6.0 4L80E top bell housing bolt
Having to change out my failed 4L80E transmission. How do you access the top center bell housing bolt? Is there a trick to putting the vent tube bracket back on it? Terribly tight quarters. All help is greatly appreciated!!
racerx
Old Nov 7, 2021 | 1:53 PM
with trans mount out and the trans supported by a t rans jack....lower the trans so it tilts down at the back. This will allow you to access the bolts with a long extension. I use a tranny extension made for just that job...1/2 end for the impact but 3/8 on other end for more access with a smaller socket
Old Nov 7, 2021 | 8:05 PM
Thanks for the reply. I can get the bolts off. How do I get the bracket back on the stud? I can't reach anywhere near the bolt. There is even a body lip in the way. This is with it dropped all the way down. I can about come as close to reaching it from the top, but still no real luck.
Old Nov 7, 2021 | 8:46 PM
magnetic socket or masking tape on the bolt head to hold it to the socket....with the extension push it thru the bracket and lift in place...thats how i do it but im using a hoist...not on the ground in a driveway.
Old Nov 8, 2021 | 2:42 AM
Thanks. I'll try rigging it up. No driveway here. Nice shop, but lower ceilings and no luxury of a lift. Just good ole jack and stands. Appreciate the guidance.
boxtruckcamper
Aug 20, 2021 7:53 PM
trainwreck91
Aug 17, 2014 6:56 AM
mndogez53
Aug 27, 2013 11:36 PM
raidrmark
Oct 11, 2012 4:12 PM
