2007 Suburban A/C Controls
Old May 16, 2014 | 2:35 PM
afwilson's Avatar
Default 2007 Suburban A/C Controls
From reviewing other threads, it looks like I have a blend door actuator problem. (most likely). Problem is which one? Symptoms are: Driverside A/C blows hot air intermittently. Passenger and rear seem to be fine. Also is there a diagram out there showing where they are located? Link? Thanks in advance.
Again..Any help would be greatly appreciated.
Thanks
Old May 19, 2014 | 2:37 PM
afwilson's Avatar
Any idea which one or where I can get a diagram on their location?
Old May 19, 2014 | 2:48 PM
Welcome to the forum...
Have you tried the re-learn procedure first?
I'd try that before doing a repair that may not be needed.....
The relearn procedure is to pull the HVAC fuse,wait 10 seconds reinstall, turn key to ignition on no crank, wait 1 minute while system relearns. DO NOT make any adjustments while re-learn is in process or system will not work correctly.... FYI anytime the battery is disconnected this procedure MUST be done or HVAC system malfunction will occur....
Also if you search the forum there are procedures on how to replace the blend door actuator.. :-) :-)
Old May 19, 2014 | 3:49 PM
bird's Avatar
FYI,
I tried the re-learn a few times, but the problem returned randomly.
I haven't noticed it return since I replaced the battery in November.
How old is your battery?
Old May 19, 2014 | 4:24 PM
If the battery dies or drops too low , it can cause the HVAC to act up...
Since it has not acted up since you replaced it I would suspect that could very well be what might have happened if you have not has to re-learn it since...
Craig6
Oct 14, 2014 10:13 AM
tomerhardt@ymail.com
Sep 21, 2014 10:26 PM
bamafutbal
Sep 16, 2012 7:51 AM
gkdors
Oct 20, 2010 6:28 AM
jasonthf
May 21, 2009 11:24 PM
