Old Jul 22, 2015, 2:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Towing and Hauling
Print Wikipost
2007 Suburban - trailer brake wiring harness
Old Nov 4, 2006 | 8:25 PM
j28s's Avatar
Default 2007 Suburban - trailer brake wiring harness
Have a 2007 Suburban and trying to hook up the trailer brake (note it has a tow package and has the four wires under the dash to hook up).
I hooked up the trailer brake and nothing (note: hooked up to trailer and no power). I disconnected the four wires to the controller from the truck. I checked the readings to each wire with the truck on...checking the red (battery positive) and the white (battery negative) there was no power. Is there something else that needs to be done? the fuses are fine. thanks for the help.
Old Nov 5, 2006 | 1:21 AM
Brady's Avatar
Default RE: 2007 Suburban - trailer brake wiring harness
Search the Tahoe forum, this was talked about a few weeks ago. You need to connect the wire that is located between the UBEC and front fender to a stud located under the cover of the UBEC. You will find the answer there. I will check back here later to see if you found the answer.
Old Nov 6, 2006 | 12:19 AM
j28s's Avatar
Thanks for the info. Found the post and it was exactly what I needed. I have everything hooked up and tested and it's good to go. Thanks again!!!
electrichorseman
Jan 17, 2025 12:05 PM
intheknow
Jul 24, 2014 10:38 AM
mefref
Jul 12, 2014 6:07 PM
sswarin
10
Apr 1, 2010 2:23 AM
mkrober
Jan 21, 2008 2:59 PM
