2008 Suburban Side Mirrors
Old Feb 21, 2014 | 12:26 PM
cunninwl's Avatar
Default 2008 Suburban Side Mirrors
Passenger side mirror only moves left & right, currently stuck in down position from backing up. Driver side mirror only moves left or right. Going to check the fuses after work. Also, as of 2 days ago, passenger side mirror sometimes folds in electronically & sometimes it doesn't. I manually fold it in and it will unfold unelectronically. Anyone had this issue? If so, is there an option before buying new mirrors.
Old Feb 21, 2014 | 11:03 PM
Welcome to the forum.
I always recommend leaving the reverse tilt-down feature off. After all, how many times do you parallel park. Saves a lot of wear and tear on the mirror mechanism. On those occasions that I do parallel park, I tilt the mirror down. Think I've done it twice in the last three years.
Old Feb 22, 2014 | 9:06 AM
intheburbs's Avatar
If it was a fuse issue, the mirrors wouldn't work at all.
Sounds like it might be an issue with the switch. Check the contacts for corrosion.
Old May 17, 2020 | 8:09 PM
SPMC9's Avatar
mine is doing the exact same thing
Al Tan
33
Jan 23, 2019 5:28 PM
niceguy88
Uplander
Jul 21, 2015 6:14 PM
Little Camper
Aug 3, 2014 1:55 PM
2500_Gasser
Feb 7, 2011 9:34 PM
ronsecord
Cobalt
May 21, 2008 8:36 AM
