2008 Tahoe Intro Date? 6 Speed Transmission?
Old Apr 17, 2007 | 7:35 PM
Tahoeguy2's Avatar
Default 2008 Tahoe Intro Date? 6 Speed Transmission?
I recently heard a rumor that GM is going to be putting a 6 speed transmission in the 2008 Tahoes.Can a GM factory or dealer guy confirm this please. I bet this will help the MPG a bunch.
Also, does anyone know when the 08's will launch? I heard Aug but could not confirm the month with anyone at GM.
Old Apr 17, 2007 | 8:09 PM
ZX1100F1's Avatar
Default RE: 2008 Tahoe Intro Date? 6 Speed Transmission?
The 2007 Tahoe's are scheduled to be built thru June 15th, then the plant will close and build on the 08 models will commence on or about June 25th.
The 6-speed auto will become standard in all the 2008 1500 products. (Tahoe, Suburban, Avalanche, Silverado etc).
There will also be a Hybrid Tahoe for 2008 that will get 4-5 more mpg.
Old Apr 17, 2007 | 9:09 PM
doo600's Avatar
What is the advantage of a 6 speed? Are they time tested reliable like the current transmission or are the new buyers guinea pigs? I really don't see why people are in such anticipation of this. I would rather see the current small annoyances fixed. Things like turning the DVD on from the front seat, getting the Nav/Radio to automatically adjust brightness for day and night and getting the remote start to run longer than 10 minutes.
Old Apr 17, 2007 | 10:21 PM
BigAlCaribe's Avatar
I've heard that the 4 speed final drive ratio isslightly higherthat that of the 6 speed on the 4x4 tahoe. Does that sound correct?
-Al
Old Apr 18, 2007 | 2:35 AM
engine2's Avatar
ORIGINAL: ZX1100F1
Will the hybrid be available in Flex Fuel as well?
Old Apr 18, 2007 | 10:25 AM
Tahoeguy2's Avatar
zx100f1...Thanks for the info. That is exactly what I was looking for. You must be a GM employee!
Re the 6 speed, I believe that this is a current transmission on other verhicles. I had heard that the reliability has been excellent. Is this correct? Also to expect about 1 mpg better gas mileage at highway speeds. Does this sound about right?
Old Apr 18, 2007 | 2:18 PM
ZX1100F1's Avatar
The ratio's for the 4 vs. 6-speed are as follows (not a huge deal) and the 6L80 6-speed trans has been around the block and has proven to be an extremely robust unit.
4L60E gear ratios: 1st 3.06, 2nd 1.75, 3rd 1.00, 4th 0.70.
6L80 gear ratios: 1st 4.02, 2nd 2.36, 3rd 1.53, 4th 1.15, 5th 0.85, 6th 0.67
Old Apr 18, 2007 | 2:29 PM
ZX1100F1's Avatar
ORIGINAL: engine2
ORIGINAL: ZX1100F1
The Hybrid will initially not have Flex-Fuel capability.
The 5.3L engine will still incorporate Active Fuel Management though.
Navigation system is standard on all Hybrid Tahoe's as well.
Old Apr 18, 2007 | 6:37 PM
rs_mn's Avatar
ORIGINAL: ZX1100F1
The 2007 Tahoe's are scheduled to be built thru July 19th, then the plant will close for a couple of weeks and build on the 08 models will commence.
FYI, this was posted on pickuptruck.com in their 2007 Denali review. GM is putting out some mixed messages about the 6 speed tranny in the 1500's.
Other GM full size pickups should see their mileage numbers improve once the six speed transmission rolls out to the rest of the light duty haulers, but this won’t occur until the 2009 model year at the earliest – a fact confirmed during and after the New York International Auto Show by GM’s product and communications staff.
Old Apr 18, 2007 | 8:03 PM
ZX1100F1's Avatar
Actually GM hasn't made any official statements regarding the 6-speed auto in the GMT900 1500 products, and if you try to pin down a PR or Marketing guy they will always deny everything.
The announcement will happen at the end of the month.
