2011 Suburban engine light on code: P0010
Old Sep 8, 2019 | 1:35 AM
Mia Threat's Avatar
Default 2011 Suburban engine light on code: P0010
I have a 2011 Suburban with the engine light on. Went to Advanced Auto Parts to have the code read. Code: P0010 is what was given by them. What parts would be associated with this code, that I will need to have replaced
Thank you for your help!!
Old Sep 8, 2019 | 10:31 AM
Welcome to the forum. A Google search reveals that code indicates it is some type of timing issue possibly dealing with the camshaft. Probably best to take it to a dealer or independent mechanic to deal with the issue.
Old Sep 10, 2019 | 7:47 AM
It could be as simple as the cam shaft position sensor, but it could also be the wire harness that runs to the sensor, it could also be a bad signal from the crank shaft position sensor that is causing a false cam shaft error. The cam shaft position sensor connector could be corroded and simply needs to be cleaned. I know this may make it seem more complicated but the the code is only a place to start not necessarily the actual problem.
powmetalr
Mar 19, 2018 8:15 AM
pszack
Cruze
Aug 6, 2017 3:21 AM
losone
May 17, 2016 8:06 AM
mastercraftka
May 23, 2014 12:19 PM
shetluck
May 30, 2013 6:58 PM
