2011 Suburban low battery
2011 Suburban LTZ recently started saying low battery after turning the engine off and leaving in on position I do this all the time so the kids can watch a movie with the engine off but now as soon as it is shut off within less than a minute everything shuts off and it says low battery start engine....battery less than 1 year old had test at Walmart (where I bought it), Orileys and the dealership and all say battery is good. Dealership says no sensor to cause issue.....anyone got any ideas?
Welcome from Florida. You should not leave the ignition in the on position when the motor is not running. You should use the accessory position. Try this and see if it helps.
That is the accessory position....I have had this Suburban for almost 2 years and it just starated doing this bout a month ago
Maybe after all that movie watching the battery has had it. Get your battery tested/replaced
Yep battery is getting weak.
Vehicle batteries are made for starting the engine only and not running accessories for more than a minute like delayed lighting. That's why they make marine/deep cycle batteries for powering accessories with engine off for extended periods.
Actually there is a third choice. An RV battery which is a combination of a start and deep cycle battery.
