2011 suburban starting issues
Old Nov 16, 2019 | 10:42 AM
Matthew Cowher's Avatar
Default 2011 suburban starting issues
I have a 2011 Chevy suburban LTZ and I am having electrical issues. I have replaced the battery and I have installed a new alternator. The issue I am having is the suburban struggles to start after you turn it off.It acts as if the battery does not have a strong charge. Every time I start it all options on the dash have reset to a factory default. Any ideas on what else I could check would be a great help.
Old Nov 16, 2019 | 11:21 AM
probably a bad connection somewhere. Make sure they are tight :
- battery ground
- engine ground strap
- starter terminal
Old Nov 17, 2019 | 4:11 PM
TrentC's Avatar
For a while, I had a bad terminal connection on the battery in which when trying to start the vehicle on occasions, would cause it to lose good connection to the battery. This would result in losing battery power altogether to the vehicle. I would have to go and jiggle the connection to get power again.
mstewart39
Jul 9, 2017 7:14 PM
Scotiapilot
Mar 15, 2016 12:35 PM
codymack2
Apr 7, 2014 2:28 PM
dankorpi
Dec 4, 2013 11:43 PM
dgbrooks
May 11, 2008 4:07 PM
