2012 Tahoe 5.3 Lifter replacement
Old Sep 29, 2021 | 4:16 PM
MatthewAF's Avatar
Default 2012 Tahoe 5.3 Lifter replacement
After the dealership told us $4500 for half, $6200 for whole, our truck sat for awhile. Got quoted $3500 from another mechanic for the whole engine, but I figure I have too many tools that don't do much. So I'm going to spend the $950 I got it figured to now to order parts online & do the job myself.
Just looking for answers to a few vital questions
VLOM - Does it need to be replaced, or can it be repaired?
Without seeing it first is there a way to judge wether I'll need a Cam replacement? Believe Truck was driven less than 20 miles after the lifter blew.
Last edited by MatthewAF; Sep 29, 2021 at 4:43 PM. Reason: Additional question added to post
Old Sep 29, 2021 | 9:43 PM
MatthewAF's Avatar
Default VLOM replacement required
https://chevroletforum.com/forum/200...erience-84428/
I see it's pointed out here why VLOM replacement is necessary & why it was at fault for lifter failure in the first place.
Old Sep 30, 2021 | 3:19 AM
oilcanhenry's Avatar
Lots of issues with cylinder deactivation. Have been since Cadillac tried to do it back in the 1970's. I like all my cylinders firing, but then I only had one cylinder when I was racing dirt bikes, so maybe that's just me.
Then again, they were all two-strokes, so kinda like having two cylinders, since they fired on every stroke.
Old Sep 30, 2021 | 8:57 AM
MatthewAF's Avatar
Default Expectation of future lifter failure
I see it keep being said that if a lifter failed once, it'll happen again...
I've also seen it said lifters on these engines should be replaced every 60k, I'm over 110k. We bought the Vehicle over 80k miles with no service records, so no knowing if this or anything else had happened before. So if I replace all lifters, VLOM, Gaskets, etc... Can I figure I'll be good for another 60k+?
Old Oct 1, 2021 | 1:10 AM
I don't see why not.60K isn't all that many miles.
Old Oct 1, 2021 | 8:05 AM
repairman54's Avatar
130k miles on my '11 5.3, bought it at 30k. Only full synth. oils in it and a Range AFM eliminator installed when I first got it. And it tow with it also. Nice quiet lifters also.
Old Oct 5, 2021 | 12:59 PM
MatthewAF's Avatar
GM 5.3L AFM/DOD Active Fuel Management Lifter Replacement Kit Gasket Set,Head Bolts,Full Lifter Set,Lifter Trays,VLOM https://www.amazon.com/dp/B07HZ2QR25/ref=cm_sw_r_apan_glt_fabc_Y51PB95DY1B8NMCNQJTZ?_en coding=UTF8&psc=1
Any Opinions on this kit for majority of necessary lifter replacement parts?
Mickeyg316@gmail.com
Oct 5, 2021 12:32 PM
SeanDillon
Sep 12, 2021 9:52 AM
lukealan818
2007 - 2013 (GMT900)
Jan 26, 2020 7:53 PM
Davy Russell
Apr 25, 2018 2:38 PM
lroppo
Jan 10, 2016 11:10 AM
