4x4 problem
Old Jun 22, 2024 | 7:22 PM
willzale's Avatar
Default 4x4 problem
Hello I am new to the forum. I have bought a 2002 Tahoe that has been sitting for a couple years. Runs fine shifts great however, went down a dirt road and decided to test out the z71… got halfway up a hill and realized that even though the buttons indicated I was in 4x4 I was only in 2 wheel drive. Tried low gear and It definitely went into the low gearing. But still no four wheel drive. So I went to the auto store and bought a new actuator motor for the front axle. No change. The car thinks it is in 4x4 however is is only sending power to the rear axle. Is there anything else besides the transfer case that it could be? Or am I screwed lol?
Old Jun 22, 2024 | 8:08 PM
How did you arrive at this conclusion? What did you actually see?
Old Jun 22, 2024 | 10:20 PM
willzale's Avatar
I tried to go up a bank and saw only the back tires move even though it was in 4x4
Old Jun 22, 2024 | 10:49 PM
OK and were you stuck, or... ?
what were the front wheels doing? (BOTH of them)
Old Jun 23, 2024 | 7:05 AM
willzale's Avatar
The front wheels( both of them) were literally doing nothing. Both rear wheels were spinning but none of the front wheels were spinning. Even though I put the car in 4x4 there is no power going to the front wheels.
Old Jun 23, 2024 | 8:29 AM
how can you see the front right wheel from the driver's seat?
what kind of transfer case is it?
Old Jun 23, 2024 | 2:22 PM
willzale's Avatar
My dad was with me and got out to verify no wheel spin in the front. It’s a 246 transfer case
Old Jun 23, 2024 | 9:01 PM
This problem is best diagnosed with the proper diagnostic equipment. A lot electronics involved.
The NV246 is an “active transfer case” that is computer controlled, has an internal clutch pack and fork to apply the clutches and has 2WD, A4WD, 4WD HI, 4WD Low and neutral positions. Three speed sensors each send an AC-voltage signal. The vehicle-speed sensor informs the powertrain control module (PCM) of the vehicle’s road speed. The PCM forwards this info to the transfer-case shift-control module through a Class 2 serial data bus. The other two speed sensors monitor front and rear output-shaft speeds.
Old Oct 2, 2024 | 10:18 AM
Willzale2002Z71's Avatar
Hey guys just an update, first off my phone got hacked and lost my account. Second the transfer case was bad. Got it swapped out at a junkyard with a junkyard transfer case. Now. My problem is that the service 4wd light comes on when the car is turned off for more than an hour. When it comes on if you drive it and then restart the car (sometimes) it’ll go away. I’m suspicious of the encoder motor because when it happens all the lights on the buttons go out except the backlight. (doesn’t show it in 2wd). I know I should read the codes but I don’t have access to a reader that can do it and the shop near me, the diagnostic fee is the same as the encoder motor.
chaser435
Apr 21, 2024 5:45 PM
333JCITB333
Jun 2, 2020 9:58 AM
JaceF8
Oct 31, 2012 7:15 PM
stevesobel24
Dec 2, 2011 1:10 PM
deerdog1
Nov 14, 2011 10:13 AM
