95 tahoe help please no where else to turn
Old Aug 21, 2022 | 7:11 PM
Yukoetahon's Avatar
Default 95 tahoe help please no where else to turn
First off good afternoon eveni g to you fine enthusiasts i apoligize for being a needy ***** but i have come in to a issue that i have run out of options for help, ive heard great things about your forum from a few friends .
I have a 95 chev tahoe w 383 stroker
Its been parked for a few years it starts up idles but when i try to move it it will stall out. Also if get it moving and i am on the road and go to accelerate it will bogg out almost as if its stalling at about 60 kmh or so
Ive read anything from vacuum lines to plugged exaust injector issues throttle body pretty much nothing that narrows it down
All new plugs plug wires distributer fresh gas inline fuel filter changed
Again i apoligize for doing this on my first post. But ive tried mechanc shops. Im in a small area so im limited to fountain tire or local shops that charge a ridiculous rate
Thanks
Could the cold air intake be giving me grief?
The beast im trying to sell
Old Aug 22, 2022 | 6:06 AM
Wavelength's Avatar
If this is a carbureted model, check and make sure choke is working properly and there is no restriction to fuel flow.Cheers.Wavelength.
Old Aug 22, 2022 | 7:46 AM
oilcanhenry's Avatar
Thanks
You don't need to apologize for anything. That's what we are here for: to help out folks like you. Lots of talented folks here
Old Aug 22, 2022 | 11:13 AM
repairman54's Avatar
3 yr old gas causes all kinds of problems.
Is that fuel injected or a carburetor ? If injected I don't see a MAF in the intake pipe and that will be a problem.
Old Aug 22, 2022 | 2:15 PM
Yukoetahon's Avatar
fuel injection model
Old Aug 22, 2022 | 2:17 PM
Yukoetahon's Avatar
i will have to take a look at that. Thank you Yea its injected i replaced all the gas even put injector cleaner ect in hoping it would waah away the gremlin
Old Aug 22, 2022 | 3:30 PM
Welcome to the forum. I would check the fuel pressure while you're troubleshooting.
Old Aug 24, 2022 | 2:37 PM
Yukoetahon's Avatar
so i did some digging and it looks like a bunch of vaccum lines were either removed or who knows. looks like the shop forgot to put a bunch of the sensors back on . right now im just going through finding which lines are missing or rotted. pressure is all good. but will update once my lines come in along with a sensor thats just imissing
Old Sep 16, 2022 | 2:19 PM
spyncycle's Avatar
Exhaust restriction? Possibly clogged catalytic convertor?
Old Sep 16, 2022 | 8:02 PM
crabi53263@aol.com's Avatar
I have seen a coolant temp sensor and an O2 sensor do the same things, I have a 96 and a 2001 right now, i have had the TBI models to, converters being plugged, dont think it has a MAF but they get crap on them and make it run like crap, sounds like once you get past the vacuum lines and stuff you may resolve it though,
