96 Tahoe Driveshaft Alignment
Old Jun 26, 2007 | 6:55 AM
.:fLiPt:.'s Avatar
Default 96 Tahoe Driveshaft Alignment
I just pulled the rear drive shaft to replace the u-joints on my 96 Tahoe (2Dr/4WD). I tried to mark their position, but found when I went to reinstall that those markings should have been more precise. I assumed since the slip yoke had a "gap" in the teeth it would only go on one way, but I was wrong. I managed to get the drive shaft back in, but now I feel a little "bump" (very subtle, not hard)when I start or come to a stop. No vibration I can feel at highway speeds, but I'm worried I could be just a tooth or so off. Is this possible? If so, how can true it up properly? Thanks...
fLiPt
Old Jun 27, 2007 | 1:34 PM
ZX1100F1's Avatar
Default RE: 96 Tahoe Driveshaft Alignment
Generally not getting the driveshaft back on the original spline will not cause a problem like you describe.
Did you grease the splines?
blueinterceptor
Dec 25, 2012 10:11 PM
NIevo
Apr 28, 2009 11:28 AM
mic454
Oct 25, 2006 7:58 PM
BassTracker
Jul 14, 2006 9:11 PM
