Door alignment 07 Tahoe
Old Oct 24, 2006 | 7:14 PM
mic454's Avatar
Default Door alignment 07 Tahoe
Has anyone noticed if the back of their passenger-side rear door doesn't line up flush with the rear fender? Mine is aligned all the way around, except from about the door handle down. I was just curious if this was a typical panel alignment issue, or a unique problem on mine. Maybe it improves mileage or something...
Old Oct 25, 2006 | 7:53 PM
tahoe07's Avatar
Default RE: Door alignment 07 Tahoe
Mine lines up all the way around except for about 6 inches right behind the door handle. It re-aligns below that and is fine to the wheel well. I would never have noticed if you hadn't asked so maybe mine isn't as bad as yours.
Old Oct 25, 2006 | 7:58 PM
mic454's Avatar
Thanks for the reply. Mine is pretty bad compared to what you described, but the door still touches the seal. Mine sticks out about an 1/8th inch from the handle through the fender flare area. I'll get the dealer to look at it, but I worry that they can make it worse than it is...
Thanks again!
Michael
blueinterceptor
Dec 25, 2012 10:11 PM
brenteric69
Oct 5, 2011 9:32 PM
davidt18
Oct 10, 2009 2:40 AM
NIevo
Apr 28, 2009 11:28 AM
.:fLiPt:.
Jun 27, 2007 1:34 PM
