97 suburban door problems
Old Feb 7, 2010 | 6:58 PM
baddog15's Avatar
Default 97 suburban door problems
I have a 97 K1500 suburban, the front drivers door handle doesnt work but outside one does. ALSO rear drivers side passenger door is stuck and wont open on unlock or lock, door handles work but door wont open. PLease help whats the best way to fix these problems?
Old Feb 7, 2010 | 7:01 PM
maxxman04's Avatar
pull door panels off, check all the linkage and linkage bushings. they tend to wear out over time. most of the plastic pieces can be found at most parts stores.
Old Feb 7, 2010 | 7:15 PM
baddog15's Avatar
ok i will try that for the first one but cant pull the panel off the back door cause its stuck in the closed position. also anywhere i can find a step by step prochedure on how to properly remove the door panel? thanks a lot
Old Feb 7, 2010 | 7:23 PM
maxxman04's Avatar
easiest to pick up repair manual. there are screws in the armrest, otherwise panel pulls off, with some pulling. it's held on by plastic, push snap lugs. once all those are pulled loose, push whole panel upwards to release snaps at window channel. you will have to pull electric window/door switch off too. a slight pry should pop it off. hope this helps.
Old Feb 8, 2010 | 7:55 PM
HEAVYCHEVY1996's Avatar
I've taken those door panels of my 1996 alot of times it's really easy once you get them off to see whats wrong. Take your time don't rush because you want to see what is not moving when your removing the panel. start off with the two screws on the handle where you close the door from the inside. The housing around the handle (inside) simply snaps off, but be careful not to break those clips or your housing will never stay flush around your handle again. All around your door panel are little clips.
Follow what maxxman04 is saying also he is taking you down the right path. Once you get the door panel off it's easy to see how the door works. There are two rods one goes to the locking device and the other goes to the outside handle. I do alot of stereo stuff to my truck so I take panels off to play with the speakers alot.
Many heads are better than one.
funnyguyMI
May 4, 2025 6:10 PM
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
dillon1001
Jan 7, 2015 10:39 AM
mwehrste
Dec 29, 2014 11:19 AM
arktrans
Jun 29, 2011 12:06 AM
