aftermarket halo headlight installation help/ideas
Old Jan 3, 2013 | 3:02 PM
kstyls's Avatar
Default aftermarket halo headlight installation help/ideas
Hey guys, i have a 1998 tahoe and have some aftermarket halo headlights that i want to install. Has anyone put any in? Any advice on installation? The set i have has wires that need to be wired into a power supply to piwer the actual halos. If anyone can help, i would greately appreciate it
Old Jan 3, 2013 | 4:04 PM
Welcome to the forum...
Did the lights come with the ballast (power supply as you called it)
Old Jan 3, 2013 | 5:28 PM
You'll need to connect them to either the parking lights or headlites, depending on when you want them on. You may also need a relay in order to have a dedicated 12V source.
Old Jan 3, 2013 | 6:11 PM
goggle "the retrofit source". It will have all the information and links you need.
Old Jan 3, 2013 | 11:11 PM
kstyls's Avatar
I want the lights to turn on when i turn on the parking lights, so do i just splice them into the parking lights?
Old Jan 4, 2013 | 12:05 PM
Depends on the current draw of the halos.
Old Jan 4, 2013 | 8:01 PM
kstyls's Avatar
The lights are nothing special, no projector lights. They just have led halows around the dim halogen buld. No balast or power supply was included
Old Jan 4, 2013 | 11:55 PM
As long as they don't blow the fuse, I guess you're probably OK w/ a direct connection then.
kbaum83
Jan 23, 2015 1:43 PM
DBoxer123
Site Feedback
Oct 15, 2014 11:49 AM
Geeo
Sonic (Aveo)
Feb 14, 2013 7:26 PM
qufree
Jan 11, 2011 8:12 AM
arizonarancher
Sonic (Aveo)
May 25, 2008 6:53 AM
