Anyone with 2500 Suburban, please help!!
Old Apr 23, 2011 | 10:40 AM
dphd's Avatar
Default Anyone with 2500 Suburban, please help!!
If anyone can help answer this before I make the purchase, I would really appreciate it. The tires shops dont seem to know squat about it.
I have an 07 4wd suburban with stock 16's on it. I want to change the wheels to 20's with a 285/55 R20 tire. Will they rub, especially when I am towing my travel trailer? Its about 7K lbs.
Thanks to anyone that can help.
Old Apr 23, 2011 | 1:23 PM
MudBoggerBurban's Avatar
Default Tires
Z71Tahoe-Suburban.com > --what's The Biggest Tire I Can Put On?
This might help you out, didnt read into too much, but it should cover what your looking for.
-Travis
Old Apr 23, 2011 | 10:03 PM
If your 20" wheels have the stock offset (+31mm), then probably have no or minor rubbing which a heat gun reshaping of the fender liner will alleviate. The offset and width is important.
Old Apr 24, 2011 | 10:32 AM
dphd's Avatar
Thanks for the info! I will check into that, I didnt realize the trick with a heat gun, great idea. I also heard that if you adjust the torsion bars slightly, it will help.
Thanks again,
Dave
Old Apr 24, 2011 | 7:00 PM
NBS doesn't have torsion bars.
Old Apr 30, 2011 | 1:01 AM
dphd's Avatar
Are you sure the NBS 2500 4wd doesnt have torsion bars?
Old Apr 30, 2011 | 5:28 PM
Now that you mention it, no I'm not but you have the truck. Look under it and see and let us know. I'm curious now.
Old May 1, 2011 | 11:49 AM
dphd's Avatar
Yeah, it does have torsion bars.
JCUMV
Nov 15, 2014 6:23 PM
Dirtiest Hoe I know
Dec 1, 2011 7:45 PM
beezey
Nov 24, 2011 4:01 PM
