Auto start not working
Old Jan 2, 2014 | 1:10 PM
Ndiehm's Avatar
Default Auto start not working
I have an 07 LT burb. The remote start was working a few months ago and then all of a sudden it stopped working. I lock the doors and when I press the button to start the car the blinkers flash. There is a click in the engine but nothing turns on. Anyone run into this problem?
Old Jan 2, 2014 | 2:28 PM
Is the "Check Engine" lite on? Remote start won't work if it is. If it's not, try disconnecting the battery for 15 minutes and reconnecting.
Old Jan 2, 2014 | 2:48 PM
Ndiehm's Avatar
The CEL is on. How do I reset it?
Old Jan 2, 2014 | 3:05 PM
You need to get it scanned to see what the code(s) are and then fix the problem(s). Then get the CEL reset. Remote start should work then.
Old Jan 2, 2014 | 3:15 PM
The "check engine light" being on is a safety for the remote start, it prevents you from starting the engine if say the engine oil is low, or some other potential engine damaging concern is present.
Old Jan 2, 2014 | 3:16 PM
Ndiehm's Avatar
I just changed the oil about 1000 miles ago. It came on about that time. How do I reset it?
Old Jan 2, 2014 | 3:19 PM
Before resetting it, you need to find out what the concern is... remotely starting the engine and not resolving the issue could potentially damage the engine...
Get the code read and addressed... once addressed it can be cleared and the remote start should start working again...
Old Jan 2, 2014 | 3:20 PM
Ndiehm's Avatar
Thanks 73. Didn't see your reply before my reply to in2pro
Old Jan 2, 2014 | 3:21 PM
Ndiehm's Avatar
I'll pull the codes tonight and clear them
Old Jan 2, 2014 | 7:19 PM
trainwreck91's Avatar
clearing the codes might not be enough, you probably should pull the codes and resolve the issue first. might be something silly like a loose gas cap
