Battery problems
Old Nov 24, 2008 | 3:25 PM
houstontexas's Avatar
Default Battery problems
recently I purchased a 07 3LT Tahoe.. love it but have a few small issues, mainly the battery. On a regular basis the volt meter reads at a steady 14 but during city driving or on startup recently, the volt meter would dip down considerably under 14. So I dropped the car off at the dealer and they said could be a faulty battery installing a new one. A few days later problem occurs again so question is... is this normal for the battery to sway from 10-14 daily?
I'm not running any aftermarket radio or devices, completely stock. Sometimes during the drive around town I can see the volt meter fluctuate gradually.
Old Nov 24, 2008 | 4:45 PM
Default RE: Battery problems
It is normal for the gauge in the IP to show a lower charging state, the generator/altanator will only charge the battery if it is in need of a charge.
First thing in the morning it will probably show charging but once you get to driving it will drop down once charged, just like a battery charger would do.
Old Nov 24, 2008 | 6:01 PM
titan5's Avatar
I have found this to be true too. I saw in the manual RTFM ;-) that the Tahoe has some form of intelligent charging system that determines how much charging the battery needs and charges accordingly.
Old Nov 24, 2008 | 6:47 PM
rmckuin's Avatar
My dealer and salesman forwarned me about the way this worked. They knew that I pay attention to gauges and dials and would bring it back to them IF I noticed the charging hand flucuating. They tell me this is normal and is a part of the attempt to improve mileagehowever small?
Good luck with the Tahoethis 2008 is my 5th one. Love them!!
Old Nov 24, 2008 | 10:39 PM
Thanks for the replies guys... I had them check it out anyways because the other day my car failed to start and had to get GM roadside jump the car, but the dealer said maybe its the battery and went ahead and replaced that. Hopefully that's the end of that. Thanks for the help!
Old Nov 25, 2008 | 7:28 PM
nole76's Avatar
Good chance it was the batttery,as I had the same problem and a check of the battery indicated a cell was shorting (according to the dealer). But check the thread I had titled "Dead Battery" because ShawnVW (I think) put out some useful info about this problem.
Old Nov 25, 2008 | 9:07 PM
I wouldnt expect the factory battery to last more then about 2 yrs, its like the batteries that come with some remotes, yeah they work and do the job but they really never last that long.
Old Nov 25, 2008 | 10:21 PM
piratekeith87's Avatar
hmmmm i wouldnt say that....my brothers battery is still original in his 94 s10 blazer...never replaced still original delco....most batteries id give 2-3 years...
mwehrste
Dec 29, 2014 11:19 AM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Sirius018
Jul 17, 2010 10:10 AM
rwrows
Apr 6, 2008 12:04 PM
