Bell Housing will not detach from engine...NEED HELP
Old Sep 10, 2023 | 10:25 PM
94burb's Avatar
15 Year Member
Default Bell Housing will not detach from engine...NEED HELP
07 suburban 5.3L, 215k, Trans is a 4L60E
Dirty work is done... I removed 3 Flywheel to converter bolts (if there is a 4th please let me know). I also have removed a total of 8 bolts/studs around the Bell Housing and there is no sign of separation at all. Is this common for older high mileage vehicles? Anything I am missing or a technique that works well??
Really need help before I bust something.
Thanks
Old Sep 13, 2023 | 7:41 PM
Mike ward's Avatar
Default I used a 5 foot spud bar, used it one side then the other moving it maybe 2" up and s
Thanks
I had similar issue, make sure all grounds are off, had one I missed passenger side low on block near fly when. Used a 5 foot spud bar under motor mounts one side at a time moving it 2 inches up and down.
Finally broke lose. Be careful to leave torque conv. Stays in when she comes lose.
Other than that I would say may have a stud still in even though nut cane off. Some studs have two nuts on each of the post. Good luck man don't bust anything! Walk away take a break
nloaring
Jul 7, 2025 9:44 AM
ampecsu
Dec 28, 2021 11:43 AM
Yogi
Nov 5, 2016 6:35 PM
sleeper79blazer
K5 Blazer
Aug 5, 2010 12:06 AM
Mechanic_Not
Nov 20, 2006 11:24 PM
