A/C issue
Old Jul 24, 2022 | 11:16 AM
RHW4's Avatar
Default A/C issue
I have a 2007 Tahoe and when I push the snowflake button to turn the air on it blinks three times then stays off and it blows worm air. When I push the recirculate button it also blinks three times and goes off.
I have read online when I was searching for answers that it can be…
ambient air temperature sensor, low pressure, high pressure in the cooling system and I also tried to reset by holding the buttons in but nothing!! Any info would be awsome!!
Old Jul 24, 2022 | 7:40 PM
Silverfox103's Avatar
I don't know about all the stuff that you mention, but I will tell you what it was in my 2001 Yukon XL with manual AC / Heater controls. I had the same issue when I first got mine, about 5 years ago. I would get the 3 flashes on the AC button. By memory, as the Yukon is not where I am: 1. Make sure the fan is on at some speed, cannot be off and 2. Make sure the selector switch is on bi-level (I believe). That should eliminate the 3 flashes.
Tom
Old Jul 24, 2022 | 9:42 PM
most likely low refrigerant charge.
-is the ac compressor clutch engaging...no = low pressure is one possibility
-compressor engaging but suction line is not cold= possible low pressure.
have the system recovered to determine if the charge is low. If low, have it charged and checked for leaks; with either uv dye or electronic leak detector.
rnorman4
Aug 13, 2012 8:31 PM
tonzmn
Mar 10, 2008 1:50 PM
tahoe
Feb 6, 2008 10:48 AM
fernandito7
Oct 28, 2007 1:14 PM
e
May 19, 2007 3:00 PM
