Can’t manually open lift gate
Old Dec 17, 2019 | 8:00 PM
cjpwalleye's Avatar
Default Can’t manually open lift gate
I have a 2018 Suburban LT. when it’s very cold (below zero) I need to use the “manual” setting because the power one is inoperable below 4 degrees. When I turn the button on the ceiling to “manual” and then manually try to open the lift gate, it unlocks but when I go to lift the door manually, there is so much resistance that I can’t raise the door at all. The power opener works perfectly if above the cut off temp of 4 degrees. Anyone know what would make the manual option inoperable?
Nimetm
Sep 4, 2019 1:54 PM
Michael Biondi
Aug 15, 2018 10:13 AM
squidboy
Sep 7, 2014 6:22 PM
Dropdprpls10
Aug 28, 2014 8:56 PM
Davpmars
Jun 6, 2014 8:39 AM
